Taking apart fxdx legs for powder???
But there is no bearing on that lower triple clamp and that is what I meant. Does that just pop off the stem by hand or light tool? Or is the bearing a pain to remove from the stem like a Jap bike
I have rebuilt prob 15 sets of FXR legs now, we charge $110 to tear them down and rebuild them with fresh seals... YES use fresh seals they actually cost less than the fluid, i like spectro for fork oil but that is just my preference. if you would rather you can send us the legs we will tear them down, coat them, and rebuild them prior to sending them back... we do this all the time for customers/forum members... as far as fluid amount... i would have to check the owners manual for the amount...
Bumping an old thread because I just tackled setting up a set of these fork legs. They do require special tooling and knowledge to set them up properly. Race Tech was of no assistance with good info on setting up proper preload, so my experience setting up my new .95 KG straight rate springs required 2 different length of spacers and fork legs installed twice before I found the magic spacer length number to get my sag level where I wanted it. This was because the Race Tech springs were not the same length as the OEM springs, and Race Tech had no clue on a base line setup. They guessed, and there guess was wrong. I did some of my own math, and came up with my own spacer length.
Once I achieved the proper ride height with my new springs, I was ready to tear down my forks all the way for PC. I will post more pics tomorrow. Here is a pic of the compressor tool I bought and used. The silver spacer shown here, has to be remade out of the supplied PVC that Race Tech provides with their springs. You also have to drill it for the compressor tool.
I ran into something odd while disassembling my forks all the way for powder coat. In the lower fork leg there is a part called the "lower stop" Part #9 shown here (click link) This This part is actually a base valve with 4 oil holes and an O ring that is around the perimeter that seals it into the lower leg, forcing the oil from the cartridge, through the lower Banjo bolt, through the adjuster orifice, through the four oil holes (basically its a critical part in the compression damping). Anyways, when I got to this part of the tear down I ran into an issue. The service manual says DO NOT REMOVE this part and if I do want to remove it, take it to the dealer. Well, off to the dealer I go. My dealer did not have a puller for this part, nor had they ever removed one before.
So, I called Big Als cycle as they have built a load of top notch FXDX's. They said the valve is easily removed and they remove them all of the time. Their method was they had a really long set of needle nose pliers, that they taped the ends of and wiggled them out. I went to 4 different tool stores and every pair of pliers I found wouldnt reach or if they did reach, the handles were too far inside the fork lower to allow opening of the pliers. Here is a pic of the new valves I have waiting to install after I get the legs powdered. Pic in next post.
http://images.imagessite.com/OEM_IMA...HD00FXD032.gif
Lower stop AKA the base valves I need to remove. These are new ones I have and the pics are taken to show what I need to remove from my lower legs. The Banjo bolt that goes through the bottom of the leg, then through this, and threads into the damping cartridge. The HD service manual says this is "pressed" into the lower leg, but from what it looks like to me and what the fella at Big Als said its just the o ring holding it in the lower.
trozenhorse
01-30-2011 05:11 PM
