rinehart churchill
rinehart churchill
rinehart churchill exhaust, just orderd this exhaust from ep,have the xieds on allready with a k&n stock replacement air filter,if im right this set up should work fine with the stock map,without a tunner,ecm should be able to adjust to this little bit of change,without any problems,anyone out there running this set up,and how does it perform, mainly looking for smoothness I don"t exspect a lot of hp or tourqe change
there"s a couple of posts with them installed and even one with sound,thats what made up my mind to get them,the post with sound is under rinehart exhaust,do a search it will come up, liveing in ohio it might be some time before I get them on, because of the weather I try to keep it in storage till the salt washes away,
I"m going to try to get them on the end of feb, going to run them with the xieds and a K&N stock air filter upgrade,no tuner if im right the ecm will adjust and the xieds will give it enough fuel,running rush slipons, xieds and the K&N stock filter now and it runs fine, no surge at low speeds like before, xieds took care of that,and I still get good milage on the highway, if I stay around 65 to 70 going to work
I've got a set of these Rinehart Churchills that are for 2006-2011 Dyna and I'm going to install on my 2000 Wideglide in the next couple weeks.
You'll have to pm me when you get them installed! Better yet, start another post with pics! You've got the fire re-ignited and I'll be watching for the Eastern Performance specials. I assumed the 96 jugs were bigger or the frames were different which would change how the later pipes would mount. Thanks!
