Injector cleaner for EFI models
Location: American by Birth, SOUTHERN by the Grace of GOD!
Has anyone used any fuel injector cleaners in Their fuel on fuel injected models? I have been told that Sea Foam works great, but I am a little concerned about using anything until I get some opinions! Any thoughts on this? I know it has more than likely already been discussed here somewhere, but I just don't have time to search and read!
I use Lucas Fuel Treatment in both bikes and all my cars. Put it in every time I do an oil change.
http://www.lucasoil.com/products/dis...tid=8&loc=show
Vec (12-04-2019)
Not sure how handy you are, but it's not too difficult to pull the injectors and clean them out. Search DIY injector cleaner and you should come across a few different designs. I have used them numerous time on various bikes. Start to finish 1st time should run you 1-2hrs, wait until you fuel tank is low so you don't have to drain several gallons.
Was more concerned about keeping the injectors running clean instead of removing for cleaning! I will remove them when I do a pm on the bike, but I was interested in fuel additives and cleaners! Has anyone had any good experiences with that star Brite blue stuff that's supposed to offset the Ethynol?
http://www.amsoil.com/shop/by-produc...ine/quickshot/
I use Amsoil quickshot.
I like the way it mixes with the water and forces it out.
This new gas sucks.
I use it every now and then not all the time just to give it a water flush.
This new gas sucks.
I'm a big believer in Sea Foam...ran it in bikes, atvs & vehicles for years.
Works well as a fuel stabilizer, fuel system cleaner, and good @ removing water from your fuel.
I usually run it through my bike once in the spring, once mid-summer, and use it all winter to prevent condensation in the tank and stabilize the fuel during longer times between fill-ups.
I mix 1 oz. per gallon.
The following 2 users liked this post by V-Buster:
71on72 (12-04-2019),
pgrchaplain (12-04-2019)
