fxdx knowledge please
I'm in the process of getting rid of some chrome on my DX and the shocks are going to be the next to go. Pretty sure I'm going with the works black trackers. The guy I bought it from lowered it in the rear end for sure, but I'm not sure about the front. That is what I'm curious about. Does it look like to you guys that the front end has been lowered as well. I don't know any different and thought maybe someone might know an easy way for me to be able to tell. Or maybe someone could tell from the pic. So I hope the pic below works and you can see it.
Thanks,
Matt
Thanks,
Matt
Got around to measuring mine and it is 7" dead on to the bottom tree. But is the top of the fork supposed to be flush with the top of the top tree? I'm just curious because from what I've read I didn't think they made a front lowering kit for the fxdx, but I could be wrong its happened quite a bit before. The front springs wouldn't be wore out would they?? Its a 2002 with only 7500 miles on it. Took the pic below so maybe someone could tell me if the forks need slid down any or if they are in the normal position in the top tree.
Thanks again for the help guys,
Matt
Matt
That's your pre-load adjustment and it's out further (softer) than mine...at 185lbs solo, I have the 4th "ring" flush with the top of the tree; the tubes can be slid up into the trees to shorten their length but yours don't appear to be...bounce the front forks a few times and re-measure and/or add some pre-load with the adjuster in the photo.
Thank you for all the info sharkey. I found a post earlier that said there is a difference between the dx and dx-t triple trees because of the fairing being on the T model. Wondering if that is why there is a difference in the fender to bottom tree measurement between mine and yours. I'm around the same weight as you and I did adjust the preload as you recommended and it did raise it up a little after a little bouncing though.
As a side note, I'm glad I dug into this because there wasn't ONE thing on the front end that was the same from one side to the other. Rebound, compression, and preload were all different, there wasn't any of them that matched. So I guess I'll just get my new rear shocks ordered, mounted. and adjusted and see how the ol' girl is sitting then.
I did go through some old maintenance records I got from the previous owner of the bike and did not find anything about lowering the front end. So I guess I'll just go with that.
Thanks to all for your time and help. I can't get enough of this site. Its great.
Matt
Matt
