cant find the connectors in the frame.....
hi guys......going to add t bars to my 2005 dyna lowrider......pulled the rubber cover off on the right side of the frame to get to the wire connectors and i cant find them....should be 2 connectors a black and a gray one.....right.....i pulled a little on the wires to maybe see if the connectors were tuck back in the frame alittle but no luck.....need help..............thanks in advance...........
Take your seat off. Make sure the wiring harness isn't zipped tied to the frame. Feed the wire up from seat. Grab wires from the front and rock it. It is easier with 2 people. For some reason the pre 2006 models are harder to get those wires forward. There is a ton of wire in there and it will go. Just take your time. When I was pulling my wires I disconnected one of my connectors making it harder.
Not sure if it's a new bike-but someone may have already spliced the wires to avoid messing with the disconnects. I was certainly tempted to when I was messing with those things. After pulling them out I couldn't seem to get them back in the frame the same way. Thinking of replacing them with individual waterproof quick-connectors on each wire instead.
synisterglide
01-01-2008 09:55 PM
