Kick stand spring
I was able to replace mine without taking any parts off. Put the bike in the parked position, hook spring onto jiffy stand, then from exhaust side use short-handle flat blade screw driver and pry other end of spring onto the frame pin (put spring hook onto screw driver, place screw driver blade onto pin, then pull up on screw driver until spring hook 'slides' onto pin). It took a minute or two and a bit of patience but it worked - hope it works out for you.
Did mine a few months ago. Put bike on jack with jiffy stand extended. Lock vise grips on the spring where it connects to the stand. Hold on tight and pull out. May as well pull the pin, disassemble, clean and lube with anti-seize. Reassemble mounting bracket and reverse disassembly step to reassemble. Should only take 5-10 minutes.
