I need some help with code po563
With the codes I usually do not have much problems figuring out the problem but this one makes no sense to me.
It is throwing the code po563 which is P0563 Battery Voltage High.
Here is the deal. \
bought the bike, battery would not charge, pushed it off to get it loaded on the trailer. I have a charger that will recondition the battery and charge it at the same time. Left it on over night. Battery over night, When we pushed it off I notice the engine light came on for a few seconds and went off.
Went and got a new battery, problem solved. Bike cranks good but after a few seconds the engine light comes on and goes out in a few seconds throwing the code.
Does anyone have a idea what P0563 Battery Voltage High is when we are talking about a few seconds at a time?
How can you have battery voltage high when the battery is dead, I mean dead.
I posted this in the electrical page but go not response
dd
Here is the deal. \
dd
Here is the deal. \
dd
Here is the deal. \
dd
What year is that bike? It sounds like the voltage regulator may be going bad.
Harley had a bad run of them in 2012. Not sure if that extended to the Dynas or not though...
there was a post on here not to long ago about the voltage regulators. the moco issued a recall for bikes manufactured within certain dates in 2012. if yours is 2012 take it to a dealership and have them check on it. if it does they should replace it free of charge.
My 2012 SG got a replacement Reg... When it went out on my SG the voltage went up and down constantly. It was radical.
This is a 2005 Dyna super glide.
I did some research, best I could, and found several had this code and it was related to a bad ground. I am checking the stator and reg after I check the ground going to the battery. I am tearing down the engine this coming week for a major up grade but want to have this out of the way first.
dd
dd
dd
dd
Well this turned out simple and easy. The ground for the battery was bad. took 5 minutes to fix. No codes now.
Cranks easier to.
Yes the Regulator will get the battery, when mine went out on the Sg it got the battery to.
Mine went out before replacements where at the shops. The bad part is it went out on the first day of our honeymoon. They took care of it quick. Not one had chrome, only black. took in on a Thursday afternoon got it back at lunch on Friday.
I don't know what it is about the Dyna bikes but after getting my wife's WG I had to have one. That is why I got the super glide. I did get it for a project. I just finished a bike that took over 2 years to do so I got bored.
thanks for all the suggestions.
new to me super glide
dd
Cranks easier to.
dd
Here is the deal. \
dd
Here is the deal. \
dd
