building a hp engine
here are the general facts of the build.
There are a few things that have not been completely decided on but close to it,
Head Quarters 113 Sport Touring Package
This Premium Performance Package includes:
•All parts and labor for complete headwork
*Heads are fully ported with HVP (High Velocity Port)
standards
*New 1.900" intake and 1.570" high tuliped nitrile
coated SS valves
*Custom fit manganese bronze valve guides
*Fully radiused valve job
High performance/heavy duty dual coil valve springs
with titanium retainers
*Viton valve stem seals
*Calibrated valve seat pressures
*Machined for 1 manual compression release per head
*Compression releases
•Head gaskets
•New Cylinders with boring and honing - custom fitting
pistons
•Lightweight forged pistons
•Chain drive cams
•High strength chrome moly pushrods and conversion tubes
Premium lifters
113" Flywheel and Case Package
Includes:
Disassemble lower end
Install new 4 3/8 flywheel - balance, true, replace rods
with H-Beam high strength
Weld, Proplug, Flywheel
Timken bearing conversion
All parts required for case prep
2,271.83 2,271.83T
Rivera/Primo Pro Clutch 99-06 Twin Cam 1 4
Primary cover gasket, 94-06 Touring/Dyna
Oil Seal, Inner Primary 1 4.65 4.65T
Oring, Inner Primary to engine case, 99-06
Oil Seal Starter Jackshaft 1 7.35 7.35T
Billet cam plate and high volume oil pump kit
Gear Drive Install Kit, HQ,
Gear Drive Kit, HQ Gears,
O Ring, Cam Plate to case,
Oring, oil pump to cam plate,
MCV Oil Amsoil 20W50 Synthetic
Oil Transfer Hose
Squeeze style Hose clamps 6
Oil Filter, HD Super Premium 5 Chrome
O-ring, Oil/Trans plug 2
O-ring, Primary Drain Plug
Remove engine assembly, disassemble, full blueprint
and build, custom EFI tune, install clutch/hub, reseal
inner primary, setup gear drives and install
new cylinders, case boring, and offset
piston oilers.
heads stage 4
larger exhaust
I was originally going to go 107" but decided to go 113 inch since I was going this far anyway. That is why the stage 4 heads and larger valves are at the bottom of the list. And the cams will be gear driven not chain.
I have a set of Bassani road rage for big bore engines so this is the exhaust I will be using. Test fitted them today and they sound really good. and look great.
2005 Dyan super glide
standards
coated SS valves
•Head gaskets
pistons
•Chain drive cams
Premium lifters
Includes:
2,271.83 2,271.83T
Oil Transfer Hose
piston oilers.
heads stage 4
larger exhaust
Awesome ... so HQ gear-drive cams not chain-drive cams ...?
What's it all setting you back ... just trying to compare to some of the 120R builds I had been seeing over the past few months ...
Not sure if there was a special on the 120Rs to break into the market ... but they were going for around $5,500 ...
Congrats on the build ... when is it expected to be done ...?
R/
'Chop
R/
'Chop
R/
'Chop
R/
'Chop
I checked out a 120r engine with a build but it will not be built to the standards I am building this engine to.
I should be done in 4-5 weeks. Depending parts on hand vs ordering.
Expecting around 110-120 hp with 120-130 tq..
Price is, lets just say you get what you pay for.
I bought this bike just for this. May hit the drag some but mainly just pi**ing of metric guys.
My builder said it will never drop below 100tq..
I am using www.protwin.com
They are about 150 miles away. I got quotes from several and this was the closest to me and they were in the same ball park figure in dollars.
dd
dd
Jerzmatic
03-24-2011 02:45 PM
