Need a brighter headlight
You need to add the bulb and ballast. $32 for two of them on ebay. Or, you can get the harley LED bulb for $400. I almost forgot you need to enlarge the hole in teh back of the headlight for the connectors to fit through for the bulb as well. Where is Joe Knapp when I need him. He turned me on to this.
I have the HD LED "Daymaker" and like it. It is very bright, but it did cost over $400.
A buddy just did the HID kit on his Wide Glide and it is bright as hell. Both have value. Read the other posts on the subject and decide, but essentially, here is a summary. Both are far better than the stock lighting.
HD LED
HID
A third option is the Truck-Lite LED, but I don't know much about it. Apparently is is also very bright and may have a more favorable pattern compared to the HD light. It seems to need a replacement bucket or a, eyebrow shield due to the size. maybe someone can check in and describe this option better.
HD LED
- Very bright.
- Has a strange beam pattern that people either like or dislike. I got used to it quickly and don't regret the choice. others dislike the sharp contrast between the beam and the unlighted areas at the edge.
- Very little heat.
- Plug-n-play.
- $400+
HID
- Bright as hell.
- Less of a sharp pattern and more of a "shock and aw" spray of light. (not a criticism, just an observation. A lot of light is a good thing when the drunk guy coming at you is texting and eating a burrito while fondling the barfly he just picked up!)
- Some manageable heat.
- Minor mod to headlight bucket (enlarging the hole at the back.)
- Added wiring and stashing of the ballast.
- $35-$50 all-in.
I just got more HID's and am going to put one in my softail and the other in my sporty. I will get some pics of the install this time so people can see how simplet he install is. In my softail I can put the ballast and such inside the 7" headlight bucket and run it off the existing relay that my passing lamps run on so that will be very simple. On the sporty I am not sure where I will put the ballast yet and if i will need a relay but I'll be doing this on Saturday.
