What to look for on '10 Fat Bob
Might check for upgrades. I bought my Fat Bob used, and the salesman was surprised that it had Rush slip-ons and I don't think he ever knew it had the Screaming Eagle Stage 1 ac under the stock ac cover. If you are buying from an individual, he will be glad to show you any upgrades he has done.
Also check the front and rear fenders for paint cracking and rust, even at just 1000 miles. Look down on the front fender and check the paint around the mount brackets.
If you do get it then make an early check of the front steering bearing adjustment (fall-away) as per the workshop manual. Also add checking for play on the swinging arm bushes to your regular checks as they start to go after a few K miles. Oh and block up the wiring holes in the rear fender behind the battery area otherwise you get a jet of water sprayed onto the electrics in the area every time you ride in the rain.
Hi guys,
I was about to post a similar thread as ABBob - I'm going to try a 2010 Fat Bob tomorrow as well!
The sheared bolts issue is certainly a concern. Is there anything else that the FBs are prone to?
Is there any way to check the front steering bearing adjustment on the spot, is there anything to look out for, are we talking death wobble at a certain speed?
Al
Al
