steel braided brake lines. Place to buy?
I just got a set of risers and need longer brake lines, might as well upgrade them to braided right?
I went from 4" to 9" risers. So I order stock length +5" right?
If I want to be safe, can I order stock +8" incase I ever want to go 12" risers?
So where is a cheap place to buy?
Magnum Shielding (03-08-2019)
Here's a good reason to use magnum. Bought a used rocker, did some mods, ordered +3 fwd controls. Ordered lines +3 from Magnum. 2 months later when I go to put them on, they are too short. Called magnum, sent in the line I took off and the new one. Turns out my rocker already had aftermarket extended lines. They sent me a new line no questions asked.
Here's a couple
The clutch cable is the Harley black diamond one (got it for $40 installed due to the dealer's mistake) which looks almost identical to the Magnum Shielding black pearl brake line I have on there. Some day I will get the throttle lines too but the stock ones work for now and are black so I said screw it and left them like they are.
Here's a couple
