PO 263 Code
Old 02-02-2013, 01:37 PM
Ben Marantan's Avatar
Ben Marantan
Ben Marantan is offline
4th Gear
Default PO 263 Code
I have a 2006 Dyna Lowrider FXDLI (Fuel Injection) bike was misfiring and coughing, I pulled a PO 263 code Rear Injector Open/Low EFI how do you fix this problem. Any help will be greatly appreciated.
Old 02-02-2013, 02:54 PM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
This is what I found:
System Relay is a very likely suspect, as Steve says.
Swap the relays & see if it turns over. The relays are under the seat behind the battery. The cover will indicate which is which.
We have seen a few issues with System relays / that year.
This is on a 06 dyna
The op of this thread replaced the relay and it took care of the problem. His symptoms where the same as yours, except it ended up not starting.
Old 02-02-2013, 11:44 PM
Ben Marantan
4th Gear
thanks will check relay.
Armytanker88
07-06-2015 12:38 PM
orange dragbar
04-24-2015 11:52 PM
cdzdyna
04-17-2015 11:48 PM
markkoby
11-30-2013 07:20 PM
06dynalow
10-06-2009 07:54 PM
Quick Reply: PO 263 Code
