EVAP Solenoid
EVAP Solenoid
I removed my EVAP system from my bike due to it not working well with my Cobra FI2000 Pro Tuner. My question has anyone removed the purge solenoid? If so, what size resistor (to work as a simulator) did you use for the connector to prevent the check engine light? I have found right ups to use a 100 ohm use on cars. For now I just put vacuum caps to close it off and keep debris out but I would like to completely remove it. Also there are three wire so I would need to know which pins to put the resistor.
