Front brakes question after installing new brakelines
Hello,
Did a quick search but nothing came up. Prob a dumb question but here goes.
I got my bike back from my indie a couple of weeks ago, and due to bad weather have only been able to ride it last weekend for a couple of hours.
He changed the stearingwheel and the brakelines (used new onces from Barnett) - clutchcables etc.
What I did notice in my frontbrake is that the lever itself is more spongy than before, and the bike itself doesn't brake as good. Its a fat bob with dual front brakes but it feels more like the braking of a single front.
What should I check? Air in the lines? enough oil? How do I do these things? Please advice.
Sounds like you need to bleed your brakes. You may need to do it several times to get all the air out. If it's still a problem after bleeding the brakes many times, you might want to zip tie the brake lever to the handlebars overnight to create some pressure and squeeze out any remaining air bubbles.
You really should take (not ride) it back to the person who did the work. Why correct the work you paid some one else to perform.
If all that changed brake wise was the new brake lines, then you most likely have air in the system still.
http://forums.supertrapp.com/showthr...o-Bleed-Brakes
MorecowbellAz
02-16-2019 12:12 PM
kbuckz06
12-11-2010 08:58 PM
