Triple tree adjustment help
I got a new 2012 wideglide, triple trees have been cocked to the right since day one ( from assembly). I brought it to 2 dealers 4 differant times and they just don't get it,even telling them what needs to be done ( read about it in this forum, seems to be common problem). So going to fix my self. Here's the questions - do I need to jack the front end up? And when I loosen the tree pinch bolts to adjust do I loosen that top bolt also ( the one under handle bars)?
I'd roll the bike up to something like your garage door frame, a tree, or telephone post and tap the front wheel against it in the direction you want it to go.
I'm not talking about slamming it against anything, just kinda hit it up against it. Make sure you don't dent your fender up.
If that doesn't work then your going to have to loosen the bolts that hold your fork tubes to move it. Unless your fork tubes come through the top of your trees you shouldn't have to jack the bike up. I'd just break the bolts loose enough to get it to move.
Best bet would be to sit on the bike holding it up, and have a friend hold the front wheel between his knees and move it where you want it.
I'm curious as to how the trees are crooked? Not insulting or anything like that, just trying to understand the issue.
I don't see how they could be crooked once the fork tubes and front wheel is mounted.
Is it not just your bars/risers that need adjusting? Is your front tire wearing improperly?
A picture wouldn't show it, you notice it when rideing, bike tracks fIne and straight. It's if you look at the triple trees, they are twisted in the fork tubes more the right and not center with tank. It's not the bars or the tank, it's trees are not center. They may be off a hair, but I notice it.
