Alternatives to powder coating
Wanted to get your opinions on this topic. I had some old parts from my bike and decided to do some experimenting. I sanded down a chrome piece that I will not use anymore and painted it with the matte black high heat rustoleum. No primer; just a thorough clean and two coats. It turned out looking really nice. Seems pretty durable as well. What do you guys think of this approach vs. powder coating? Does anyone have experience with this and the long term out looks like? I'm thinking of taking a few other parts on my bike black and may use this as a substitute to powder coating. Thanks. Robbie, would you even consider this for the raw fender?
Might look ok for a few months, but it is going to chip and turn color on you. If it is something you dont mind removing and repainting every 6 mos...go for it, otherwise powdercoat and be done with it.
If you are looking for that "rat bike" look....put it on your tins and then let it weather. Rattlecan paint jobs are almost a must in that case
With that said, powder is the way to go.... if you got the time and money. If not, spray paint away!
I like the DupliColor truck bed liner (also rattle can)
You can't get it off without sandblasting. Stays black, wrinkle-like finish and extremely durable. $8 a can at Lowes and goes a long way.
PC is really good and provides several colors as well as different finish options, but if wrinkle black is the goal, this stuff works great.
i've used rustoleum appliance epoxy on headlight trim, shock springs, fork lowers, battery band. has held up for 2 years w/ no problems.
good sand, clean, and as many coats as you can apply in 30 min, 5min break between coats
in the process of doing the same epoxy on front and rear wheels, trees, and a few other misc parts. i'll post a quick writeup once all is done.
spray away!
spray away!
I agree with everyone else. I suck at painting anything even with a rattle can. I usually let my buddy do that part. He's more patient than I am. I always get runs in it. If money's tight with the bike now I say spray away. It's not like it's something you can't take back off and redo if it needs it. I have another guy I ride with and that's all he has ever done to his bike.
