Problem - HD LED Headlight on '12 WG
I installed a new HD LED Headlight on my 2012 Wide Glide and it caused the red Security light to illuminate on the speedo. Waco Harley Davidson said they contacted HD Corporate about it and it was a known issue they were working on. Longhorn Harley Davidson never heard of the problem. Does ANYONE know what causes this and is there a fix yet? It doesn't cause any operating problems, it's just annoying as F. Thanks in advance for any thoughts.
Thanks for your input. I wondered the same thing. The folks at the dealership didn't seem to think a load equalizer would fix it. Would love to hear something official about the problem.
Ya I bet the load EQ would probably fix it. Another option is to wire the lights directly to the battery thru a relay. Then use the headlight circuit to trip the relay. But if the LED's don't draw enough load, the relay will draw less.
I have a 2012 street bob, after installing the led light my red speedo light goes on and off also. Another issue is my led headlight will not stay on high beam. It may be on high for 30 min or 2 min. Once it flashes back to low beam, you have to turn off the ignition and restart the bike to get high beam back on.
Does your wg do this to.
