I have a 2013 Street Bob with the 103 in it. Do the 96 engines take the same exhaust as the 103 do they fit each engine. For what I have read they are the same. Is this true?
You need to worry more about the O2 sensor bungs. Older exhausts had 18mm bungs. You bike has the 12mm. With them saying 06 and up, they may have both. If so, make sure they send you a set of plugs for the 18mm holes...
I would also check the o2 sensor placement. I may be wrong but have read where the placement is different on the 12 and 13 and may confused the ecm. Just the bungs may not work. Just being safe.
