If it were me I'd get an adjustable ignition like a Crane hi-4. That way as you progress with mods you've got something to work with instead of constantly buying ignition modules. You may not plan on it now but cams, heads, big bore, etc comes to mind before you know it.
i dont plan to do any "real" engine work but thought if this could boost a little performance out then perhaps id b worth while...
Chuck it on and try it out, its an easy swap. I just use Sportster ECU's as its way cheaper and gives the same result. Its just different advance curves in the end and SE want your dollars...
