XB wheels on my street bob.
Old 02-15-2013, 02:43 PM
vdop's Avatar
vdop
vdop is offline
Default XB wheels on my street bob.
Just a little teaser. Got them mocked up today and all spacers made. Just mock up tires on there for now. Front wheel will be black. Now I can piece together chain and brake parts for the rear. I have fatbob lowers going on the front, just need a caliper adapter. More to come once the front is painted and I get the parts and tires to finish it up. I think it looks pretty nasty so far.
Old 02-15-2013, 02:47 PM
ryderbiker's Avatar
ryderbiker
ryderbiker is offline
I dig the wheels but I'm undecided on that perimeter rotor. I know that's what the XBs have but I can't decided if its too much on the Dyna. Nice work regardless.
Old 02-15-2013, 03:15 PM
CADguy's Avatar
CADguy
CADguy is offline
Very cool and different! Can't wait to watch the progress on this build!
Old 02-15-2013, 03:42 PM
vdop's Avatar
vdop
vdop is offline
Thanks. I really wanted to mount it with the rotor on the left side like stock but it just wouldn't be possible to mount the caliper on that side with the bleeder and line where they are. Not that I mind the look of the perimeter rotor, I just wanted it to be a little more subtle. Oh well, I'm not doing it for the looks, just function. They're a lot lighter, much better rubber available, and the perimeter brake has more stopping power and weighs a fraction of a Harley dual disc setup. The look is just a bonus. When I get chain, sprockets and a rear brake setup together I'm going to do a break down of the total weight savings over the stock stuff.
Old 02-15-2013, 04:50 PM
gartec81's Avatar
gartec81
gartec81 is offline
this is a great build. good job. im tuned in
Old 02-15-2013, 10:28 PM
Redbeard's Avatar
Redbeard
Redbeard is offline
Very cool! How hard is it to get the caliper lined up on the Dyna legs?
Old 02-16-2013, 12:23 AM
rs87277's Avatar
rs87277
rs87277 is offline
Dang bad azz
Old 02-16-2013, 01:47 AM
66Vair's Avatar
66Vair
66Vair is offline
This'll be awesome!
Old 02-16-2013, 01:57 AM
EastBay_Solo's Avatar
EastBay_Solo
EastBay_Solo is offline
Nice i really dig that set up. Its different and I like that. Good **** homie cant wait to see it when its done.
Old 02-16-2013, 07:24 AM
vdop's Avatar
vdop
vdop is offline
Thanks guys. I'm pretty excited now that I see it coming together. Trying to split funds between this and the motor to get it done by spring.
Well the caliper can only mount on the right side, and the factory street bob, like most dynas, has a left side brake. So I'm using fat bob (dual disc) lowers, which I have, but haven't put on yet. Even with the mount on the right side it still needs quite an adapter to bolt up. Eagle hd in Indiana used to do this swap on v rods, which have basically the same front end as a dyna with fat bob legs. They still have the program and are machining me an adapter. Not a very cheap piece of aluminum but still cheaper than one good rotor or caliper if I were going dual disc. If I decide the xb 6 piston isn't quite enough I'll find an 1125r massive 8 piston caliper.
The front was real easy to mount otherwise. I used a stock 08-up 25mm axle, same as the Buell bearings. I used the newer bagger aluminum wheel spacers. Machined down the left spacer to stock dyna size and the bagger right side spacer fit perfect.
The rear is another story. '06 dyna has 1" bearings and the buell rears are big 30mm, and the outside diameter Is bigger too so you can't use Harley bearings. I used a rear 08-up 25mm stock axle too with the same bagger 25mm front spacers. The spacers were long enough that I machined down most of the spacer od to fit inside the Buell bearing and support the center spacer and still left a lip to act like a wheel spacer and adapter. Then just machined some spacers for the rest. The stock caliper mount won't fit with the wider wheel. I ordered a chunk of 3/8 billet that will replace the right side spacer and I'll use to make a caliper mount under the swingarm with an adjustable link. Gotta go to the sportbike graveyard and pick out a caliper for the rear that I'll use with the stock xb rotor. I'm going to cut the factory mount off the swingarm. I'll take pics of everything when it comes back apart, I was too excited and in a hurry to stop in the middle.
Quick Reply: XB wheels on my street bob.
