Does this sound like a bad stator to you? '09 FXDF
Last fall, my '09 Fat Bob FXDF with 7800 miles on it decided not to start one day. It showed the dreaded check engine and battery lights on the dash. I put it away for the winter and just got time to screw with it today.
I've installed a new regulator and it has a new battery.
It starts OK and runs, no lights on dash, but it's only charging at 12.16 volts at idle, and that goes to 12.17 when RPM is raised.
Thoughts?
Stator?
Tests?
Thanks!
Thoughts?
Stator?
Tests?
Thanks!
Sounds like stator. No need to check codes, obviously it has codes, obviously its not charging, obviously the codes are for no charging. Here's how to check the stator. Unplug the stator. Trace the wires from where they come out the front of the case, there will be a connector near the regulator, you unplugged it to change the regulator. On the stator side, the wires coming out of the case, you have to check ac output. Set your meter to ac and between any two of the pins in the connector you unplugged, check voltage with the bike running. Should be around 20 at idle and raise 10 volts per 1k rpm. Another test you can do is simply check for continuity between all the pins at the same connector to check for an open. Finally you can check for continuity to ground at all the pins to see if the stator is grounded. Three very simple tests that will tell you exactly what's going on.
