Handlebar Questions
Handlebar Questions
I'm thinking about switching to drag bars but was wondering how comfortable they are. I ride about 70 miles round trip a day to work. Also, when I bought my bike (02 W/G), the previous owner changed the risers to a pullback style. My question is, will the turn signals hit the tank and how do I go about figuring out the amount of pullback and or rise of the bars? Thanks for all the previous help and I'm sure all of it in the future as well.
It depends on how long your arms are. Do you have problems with the sleeves on your shirts being too short? I've got long arms, so I've ridden with drag bars since the '80's. I've ridden to Sturgis, 800 miles, in a day with drag bars on six inch risers. And no, the signals won't hit the tank with the six inch risers. I recently went with 12" straight riser T-bars because I'm in my 50's now and wanted to sit upright a little more.
One other thing, make sure your jacket sleeves are long enough because the sleeves will ride up on your arms a little more.
Good Luck
Crazy
Good Luck
Crazy
Bars pullback varies for each bar and how much pullback the risers add. Like any bars risers are going to affect the pullback altering them in relation to where your grip so your question needs more information if you want a more specific answer. Especially considered there are several versions of bars in the drag bar style line.
My bike has 6" LA Chopper pullback riser and Flanders 35 degree drag bar from sideroadcycles.com . I ride with my arms bent at the elbows relaxed but still straight out enough I can rest my wrists over the controls on long rides for a flat arm ride. After you look at sideroad for their method of bar measurement try using that and getting a buddy to help measure while your sitting with the bike straight up with the wheel pointed forward as if your riding down the road like you normal but with your arms where you feel would be most comfortable or where you want them. Either hold a piece of string between each hand or use the imaginary line method and have him make measurements based off of that. Then look at their selection of bars and decide which style has those dimensions or close.
They even got a how to measure section www.sideroadcycles.com
Mine is like someone stuck a lazyboy on an old hot rod at this point.
Hope this information helps:
I am 5' 10" with average length arms.
I added 6" straight risers, and 27" wide, fairly straight drag bars.
It is very comfortable for me. I did a 4,800 mile trip the year before last to the mountains and back, with a couple 600 mile+ days with no discomfort at all. The drag bars keep me sitting straight up in the saddle with no slouching of my lower back, which I think adds to the comfort level.
Here a few pics and a video to see the general ergonomics situation:
