2013 Street Bob LED question....
Hello. I have a 2013 Street Bob that has the rear brakes/ turn signal combination. I'm looking for red LED bulbs for the back and amber for the front. I was wanting 360 degree so that others could see when I braked or turned without having to be directly behind me like some of the directional LED's. After weeks of research and searching through the forums here I think that I found some that would work. I just wanted to make sure that they did before I went out and paid $100 on bulbs. They are the Jam Straight 1157-HAR and 1157-HRR, 360 degree bulbs.
amber
http://www.oreillyauto.com/site/c/se...eyword=1157har
red
http://www.oreillyauto.com/site/c/se...eyword=1157hrr
Any input would be appreciated. Thanks
amber
red
I could be wrong, but I don't think those lights will fit in the bullet housing.
work really well and are bright. They aren't 360 degrees, but you would need a whole different turn signal housing to have a 260 degree view anyway.
I have these in the rear signals an like them a lot.
Keep in mind, if you replace all four turn signals with LED, you will need to install a resistor in the front circuit to avoid having your dash signal indicators flashing too fast.
Don't get those autozone 1157, they are useless, I found the regular bulb is brighter. I don't know about your turn signal housing size, if it is same as previous bullet turns, they will fit.
HERE IS THE LINK
HERE IS THE LINK
