SE 255 cams with Power Vision
Hey VIN 1800, if you bought from Fuel Moto, Jamie will send you a new map for the cams. If not, which is probably why you are asking, then go to the Dyna Jet website and put in all your info and download the best map you can find - it does not have to be perfect but as close as you can. Cams, size engine, and the 2 into 1 are important, but the exact type not so much. For instance, my map says Switchback but I have a Fat Bob - same size engine but different model. You just need a map that is as close as possible, that is in the DJ library then start Autotuning it. If you still have concerns, call Dyna Jet directly, they will help you out. Good luck, I bet your bike will move!
I like how my 255s perform. Torque right off idle just where I want it. No early flat spots like the high RPM cams. I don't spend much time over 5k RPM.
It might just be my riding style, but I'll take low end torque over high end HP any day. 6th gear at 2000 RPM pulls like a train without lugging.
I'd concentrate on the timing, the fueling will be OK from most maps and autotuning afterwards will tweak things into place. Timing though needs to be right from the get-go to match your cams and autotuning won't help with this. Get it wrong and the cams will perform worse than stock.
If you are stuck then shout up and I'll let you have a timing table that should be OK but you'll need to manually enter it.
If you had a cam that actually performed well at 5500rpm, you would spend more time up there, I promise you
My bolt in cam made over 100ft lbs @2600rpm and was still over 90hp @5600. Pick the right cam and you will have power everywhere.
