Metz ME 880s or Avon Cobras
Trying to decide between these two tires when I go to 18s on my Fat Bob. If they made the exact same sizes I was leaning towards the Avons. Except Metz makes a 140/70-18 and Avon only makes a 130/70-18. I kinda wanted the fatter tire in front. In the rear the sizes are the same except for the aspect ratio. The Metz is a 200/50-18 and the Avon is a 200/55-18. Metz has the sizes I want but Ive only heard good things about the Avons and not alot about Metz. Can I get some opinions from people running either brand? Thanks. Btw, rear tire width between the two is within 1 or 2 mm so that isnt a factor. I know it can be sometimes between brands.
Wait a minute there Spankadog! Avon makes a 140 front.I would go Avon I think you would be will be much happier.The Metz have a real square shoulder and to be honest will prob be reealy tight.Crazy thing is it's only 1/4" wider than your 180 (Avon).The Metz does look good though and has a lower pro but make sure it will clear ok.(It should) Pulley will need some trimming ether way.Look what I found ya.http://www.1130cc.com/forums/showthread.php?t=149413 http://www.ebay.com/itm/SET-AVON-VEN...-/310411122486
