I have it on my bike. Install was super easy. Took all of 30 min maybe. I noticed a difference in throttle response as well as decel popping. It has 3 map positions, and tunable in each of those three spots as well. I would definitely recommend it.
Hey, Dynamite. I was just reading about this Tuner and it sounds great! I read the installation instructions online and it seemed a bit above my skill level. Particularly, raising or removing the fuel tank. Can you lend some more insight? Any help would be appreciated. Thanks!
You just need to be able to access some wiring that runs along the backbone of the frame. Removing, or lifting the rear of the tank helps expose that harness so you can get to what you need easier. Its one bolt at the bottom of the tank, then it pivots on the front bolt so you can lift it up, kind of like a trunk lid. Its really easy. Go look at your bike and you'll see what I mean. As for everything else, its all really simple. The instructions walk you right through it. Nothing to fear.
