2013 streetbob, is a super glide rear fender direct bolt on?
not sure how all the lighting is run, but you might be able to just swap it right over. if your leaving the taillight on the side you probably wont need to do any re-wiring. but if you plan on moving it onto the fender you will need the superglide wiring harness, taillight housing and lens.
I have a super glide fender waiting to be painted just been busy. The super glide fender will bolt right up if its 2007 up, you will need to check the wiring diagrams for both... If your good with electrical you can make it happen no harness.
Keep in mind that the 2013 fxdb has no center taillight. It's just got the two bullets for run turn and brake like the wide glide. That's why I think the wiring will be different.
The fender itself is a direct bolt on. The electrical is the same at the plug under the seat different near the taillight.
Easily re-workable with a test light.
