Oil catch cans
Oil catch cans
I know there's a ton of threads about blowby and crank case filters but in all the ones I've looked at it can't seem to find a good looking functional setup. I'm a 1/3qt down I still get some blowby it's not a huge deal but if there were a good fix for ok $ I'd do it. Also I get oil down the clutch cable from the tranny all the way to the adjuster? Dealer said that's normal?? How can a leak be normal? It's got the nylon braided cover if I clean that good and dry it won't make a drip for quite some time. But it seems to be leeching into that nylon on every long ride. Anyways I know that's kind of two separate issues but I don't like making threads as it is. So I figured 2birds 1stone. Thanks guys.
What year is your bike? if its a TC and you have blowby then you have some serious **** going down...or maybe you just need to replace the breather filters in the rocker box.
If its an Evo it still shouldn't be doing it unless its a crankcase breather model (early) in which case extending the breather out the back of the rear fender is a good cheap fix.
The moisture that seeps down the outside of the inner cable sheath and drips the occasional drop is rare, but not unheard of and no, it is not "warrantiable" and can only be fixed with a clutch cable replacement.
Twin Cam umbrella valves, ( in the heads,) are supposed to stop air cleaner drip. They only do an adequate job IMO. But there is no way in hell I'm running an air cooled / OIL cooled motor anything short of the full mark.
Joe
Thanks a lot guys, this forums quick! First my bike is a tc88 2006. Like "the mouth' said I've heard that tc's are known for blow by. And yes its the sheath that the clutch cables wrapped in that seems to get wet with oil. They say it usually will just get damp around the cover but isn't unheard of to go to the adjuster. I know it, I hate some of the answers I get from my dealer. But I can't find any good indy shops near me. My bike runs mint I get no oil dripping from my a/c so it's very little blowby. Nobody runs a crankcase filter or catch can system?
