FOB problems
FOB problems
2010 wide glide has been sitting for about 2 months (Syracuse winters suck). went out this weekend to put a licence plate extender bracket on (getting some new bags), but the fob was not working (lights blinking, no start). Changed the fob battery, but no luck. Retrieved the spare one and works fine. bike started up, so the bike battery wasn't dead.
My question--would this thing just go bad? could the bike "forget" the code if battery was low or not used in awhile? it was working when i parked the bike...?
Similar thing happened to me with my 2010 Street Bob, last month. (Same battery I presume)
I went in and got spare and was on my way. I actually haven't changed the battery yet in the old one to make sure it still works. I will be on the lookout though if I have the same issue as you with the original not working with new battery.
Also, I been riding around with both attached because I have been too lazy to buy a new battery but I was wondering if the spare fob/battery is going to die soon as well because it is same age as original??? Regardless, I need to learn the procedure to bypass the FOB and start the bike. I think procedure is in service manual.
Also, "GOOD" Idea to change both at the same time. Well worth the $3-$4 per battery investment.
There should be a card in your Owners Manual that explains the bypass procedure.
Both of mine died at the same time, thought it was the main battery until I did the bypass sequence. Mind you, they lasted 5 years.
