09 Super glide won't start
I have an 09 fxdc. Always keep battery tender when not being ridden. I took it out in jan. to get inspected. Had a hell of a time starting it, fuel pump would not prime. After plugging in to tender again, after a while she cranked up. Cranked fine after inspection as well.
Took it out this past weekend and had a hell of a time starting it again. Rode for a couple hours just fine. Did not plug into tender after ride.
Went to start tonight and she cranked right up. But, it shut off after a minute. Can't get fuel pump to prime now and won't start. All lights work but dim when the you hit start. Would the battery keep the fuel pump from priming and cause it shut off? I can see not letting fuel pump prime, but would it cause bike to shut off?
You might only have a good surface charge. These batteries don't have a lot of cold cranking amps. I'd be willing to bet you just need a new battery. Without an actual load test its impossible to say for certain but just because your seeing a good read on a meter really isn't a sure sign that its an ok battery. 2 yrs on an orig battery from HD is another sign for me anyway that it may be time to replace it. While many people get many more years than that out of there stock battery, many others dont. You might have gotten the one crappy battery in the lot....it happens....I change mine every 2 years needed or not...piece of mind ya know.......If your getting fuel once it starts and there's no sputtering or bogging there's another sign that the fuel pump and or fuel management system is probably ok. Can't rule out the run/stop switch either.
My money is on the battery. A fresh battery at this point after 4 years is a given in most cases. Might be time for wires n plugs too. Could be a combo of low amps and inadequate spark.
I'd start with new battery and if the problem proceeds it might be time for you to throw it on a computer and have a diagnostic run. While it could be anything more serious I'd start with the less serious before throwing money at it trying to guess your way through it. That battery should be changed anyway brother. 4 years is a good run.
