mikuni tuning
mikuni tuning
hey all. trying to get some more info on tuning the mikuni carb on my 2000 fxdl. at high way speeds with the throttle goin from half open to 3/4 or more open, it stutters, which is a lean setting. what is the best way to tune it? the website offers very little info on how to do it properly. thanks for any and all help!
Unlike the stock CV carb, the Mikuni has a lot more adjustment and there isn't the same small number of jets that work.
I too gave up with the "recommended" jetting and trying to adjust it by feel. I bought and used a wideband O2 meter. The jetting I ended up with was nothing at all like I had to start with.
If you you don't want the hassle of buying and using your own O2 meter then I strongly suggest getting it dyno tuned.
Increase main jet size and retune your AP duration.
From my understanding of the mikuni the main jet regulates fuel flow at mostly wide open throttle. Try changing the position of the clip on the needle first. The thing about them with four different fuel circuts really fine tuning can be a pain. After my 5th or sixth time changing jets and the needle I just let a pro dyno it. Case closed for me.
