O2 sensor plugs on V&H
I am going to be installing some V&H on my 13 bob, and I will be using a FM micro and deleting the O2 sensors per FM recommendation. On the instruction sheet for the pipes, it states to use anti seize compound when referring to installing the 02 sensors. Clearly, I want to make sure the plugs I will be using don't come loose or leak any air, so should I use the anti seize compound, or would something like regular locktite work better? what about silicone tape on the threads to prevent air leakage....or would the heat be too high? What is the best option here?
thanks.
thanks.
They used to make copper anti seize for heat but I don't think heat will really effect the silver either. I doubt they will ever loosen, usually plugs will seize in exhaust. If it were me I would "never seize" just in case I ever wanted to remove them. If they leak you would probably never know it.
