Replace primary gasket when removing cover on new engine?
I need to remove the primary cover(the whole thing, not just the clutch cover) in order to install the SE clutch spring. I'm just over 1000 miles...I know the manual says to replace gaskets any time you remove any cover...is it really going to be necessary after only 1000 miles though? Assuming the gasket doesn't come apart, obviously.
i am one of those replace gaskets everytime guys, but with canadian price of $75 for the primary cover gasket i would carefully remove the primary tryign not to damge the existing gasket and then re-torque the cover down and pray it doesnt leak. worse case scenario is you leak a bit and have to re&re the cover for a new gasket
If only the moco had been that smart. Definitely can't fit clutch plates through the hole and I've read that the spring I'm replacing won't fit either.
Listen, I have never replaced my primary gasket, derby cover "O" Ring or ( in my case,) the inspection cover gasket these bikes used to have.
My bike is 13 years old and just turned 124,000 miles. If you don't tear it, you can re-use it. Someday I'll have to buy a new one, ( maybe,) but not until this one leaks. ( I have an assigned parking space at work made of concrete, and there is not one drop of oil from my bike on that surface. The guys at the Office would have a field day with me if it ever did....)
What have you got to lose by trying? 30 extra minutes?
I powder coated a bunch of stuff on my Street Glide at 1000 miles so stuff came off and went back on, primary included. Didn't put on a new gasket on the primary. As long as the integrity of the gasket isn't compromised you should be fine. Put it back on, torque it down and check it for leaks. Mine has be fine.
