Dyna floorboards
Dyna floorboards
Has anyone done this yet?
http://www.harley-davidson.com/gma/g...bmLocale=en_US
How hard is the install?
It sounds like you've got mid controls?????
You can just install a chrome 'beauty cap' over the end of your shifter shaft and bolt the inner lever to a tie down bracket on the motor/trans case ...
It is the same solution that many adopt when switching to forward controls ... avoids the necessity of having to remove the primary cases ...
The footboard kit should be an easy half-hour or so install if you are not doing anything with the mid-control shift lever ...
Good confidence building project ... next up cams ...! LoL
R/
'Chop
R/
'Chop
