I was just curious what most thought about replacing the gasket when swapping out pipes. If the pipes are changed pretty much immediately off the showroom floor, should it require a new set of gaskets, or since they should be new already could the originals be reused? Also, is there a particular gasket brand that is recommended over others?
I will let someone else comment about reusing gaskets but make sure you are using the right type of gaskets for the new pipes - flat or the flared type. My OEM pipes used the flared type, but my Bassani RR pipes required the flat type.
I put Vance & Hines sideshots on my SG and the directions recommended Screaming Eagle gaskets. Used the SE gaskets and no problems. Gaskets aren't that expensive, why test murph's law.
I agree with all the posters. Cheap part and since you have the pipes off replace the gaskets because the heat shields were a mother to put back on. I tried the SE gaskets and ended up putting the stockers on with my V&H SSS.. One thing to remember is the torque settings..
If taking off and refitting the same exhaust then I reuse the gaskets. If its a different exhaust then I always use new gaskets. The gaskets crush to the shape of the exhaust end and this is pretty much always different between systems.
