Removing Front Turn Signals 13 Wideglide
What do I need to do to remove my front signals? If I do, will it cause my bike to throw a code? I am not familiar with the newer style connectors or electrical system on the new Dynas. Molex connectors are much simpler...I have a manual but can't find it...
The thing is, on the new Dynas, I can't find where to unplug them...There are only five wires on the right side and four on the left. I think this is a CAN bus system?
That's what I am thinking but I am leery of doing this if this is indeed a CAN bus system...I used to install car stereos when the newer electrical systems came out. You would see some funny stuff when you removed pieces of they system...
You only have to worry about affecting the CanBuss system when tampering with input signals like switches and push buttons. The CanBuss only monitors outputs for fault conditions. Such as a "short circuit" or "bulb out" condition. So you may see an indicator lamp on the dash after you disconnect the lamps.
