I have a 2013 Dyna Wide Glide. I am thinking about installing a Andrews 48H cam, HD EZ install push rods. Is there a better cam for low end/mid range torque ??
I've been looking at cams for a while and I finally decided when I do them (probably in the next few months) I'll be going with the Woods TW-222s. The full kit with directional roller lifters from Fuel Moto. Cams are the only engine upgrades I'm planning on doing and these work great with stock engines.
Have a look at Feuling cams as well. I put the 543 reaper cams in mine recently with stage 1 air cleaner & a thunderheader. My #'s are in my signature. I didn't need to change my pushrods with them & they pull from 1,900-5,000 rpm. Really woke my stock 103 up!
I have Cycle Rama 575's. 100% Stock motor with this cam bolted in. 100 ft lbs at 2550 rpm and stays over 100 until 4200. has 92hp @ 5350 rpm. The cam hits hard down low and stays there till you shift.
Green line is before SE clutch spring, red & blue after
