changing frt brake lever
STOP! You have to put a small spacer in the lever before you remove it so that you do not destroy the switch.
Pull on lever, put a spacer to fill the gap that will hold the lever open while you remove it. Once you remove it, have a look at the tiny micro switch inside. It has a rubber boot on it. Switch is about $65 and a little bit of a pain to change.
If you remember those little packages of cheese and crackers, the one that you use the little plastic stick to spread the cheese, that little plastic spreader is the exact thickness of spacer that you need. I went out and picked some up just to get the stick!
ok. got it done. thx for the info guys. the lever came out without putting a spacer in. just had to angle the the lever alittle as i pulled it out of the housing. then angled it again as i place it back in. some internet info said to separate the housing to get out the lever but on my 2008 fat bob i didnt have to do that.
