Turn Signal Isses
Turn Signal Isses
08 FXD,
Originally I had no turn signal functionality at all and no horn or brake light. I am thinking that the brake light may be a separate issue? Anyhow, I found that I had a blown ACC fuse. I replaced the ACC fuse and my turn signals and horn returned. Still no brake light. My left side turn signals blink alternating front and rear signals at the normal blink speed for 3-5 blinks (again alternating between front and rear) and then start to blink at approx double the normal speed. I did swap the front left and right bulbs to see if the problem moved (it did not). I did however notice that the left bulb is significantly dimmer than the right (I found that the right bulb had been replaced and is new looking). I will be getting a new bulb but I dont think this is the root of my problem. Maybe it is. Any thoughts guys?
Yea, check your wires. Also make sure you don't have a kinked wire or a wire being crushed under your switch housing and shorting out the system causing the fuse to blow. As for your brake light, is your tail light even coming on at all? If so but you aren't getting any light change (run to brake), chances are you might have broke the switch button on the lever and the brake light is just staying on. When you pull the hand brake lever look between the lever and the switch housing, you'll see a little button the when pushed in will deactivate the brake light, you should be able to push it in and see if the brake light goes dimmer to the run mode. If this happens, you either need to super glue an object just big enough to the button to make the switch work right or have a new switch installed.
UPDATE***
My turn signal issues turned out to be kinked wires. I took the bundle out of the frame and reorganized them then reinstalled. The signals continued to work as designed after I stuffed them back in there. My brake issue as suspected turned out to by the front signal switch. I pulled a rookie move and didnt shim the brake lever when I removed it. I will be installing the #4 screw fix in the switch this week. The switch works, just the plastic nub is gone. Thanks for all the help guys!!
IornStreetBob
06-02-2015 10:47 PM
