Whats the deal with the new DWG fuse blocks?
Ok, so I have an accessory (garage door transmitter) I need to wire in. Old school Dyna was open the harness under the seat and splice in. I have installed many of them across the whole line.
Now, the damm instructions want you to *** a slot to an open port on the fuse block. Okay, done that many times...except, there is no block anymore. all there is is a 15 amp Battery location, a 15amp P&A (accessory) location, and then the master fuse. Anyone install one of these without ripping into the wiring into the :fuse block" as it sits now? I was going to use a mini blade jumper but with the Deutsch connector no way to route the wire out without modifying the cover. I am just trying to avoid hacking things apart and keeping it elegant. Anyone who has done this please let me know.
