Main Wires HELP!!
Main Wires HELP!!
I have an 08' Street bob. Does anyone know a way to access the wires running through the "main Channel"? The area just below the gas tank but above the seat. It appears that these are main wires for operation. Yep, I nicked them drilling a hole and now I'm a little worried.
This wiring appears to be within the backbone of the frame. I see at the top near the front of the bike a plastic cover is underneath, but down low near where the seat mounts there's no access. It doesn't appear that the wires are long enough to feed one direction of the other. The only option I see is cutting the backbone, making the wire repair, and re-weld the frame. Ballsy
sorry for the wrong info i just went and looked and i see the bigger main harness running into the frame. i thought you were talking of the two smaller harness on either side of the frame under the tank. you got yourself a mess, you would have to disaseemble some stuff to get some slack in the harness so u can check the harness for damage but don't cut your frame.
If you can see copper, you should be able to see what color the wire it is. From there, find it in front of the tank and behind it. Then snake a wire and solder the ends. If you have a meter, you can check for continuity on the end of each. Then you can make sure you didn't cut anything else...
jordanball33
07-21-2010 09:00 PM
