Street Bob Primary Sump Plug
Old 03-19-2013, 10:05 PM
SPERO56's Avatar
SPERO56
SPERO56 is offline
Default Street Bob Primary Sump Plug
Hi guys - I need some advice. Just done my first oil change on my 'bike. All went well apart from trying to get the darn Primary Plug off. Whoever last serviced my 'bike must have used an air tool to put it back on.
When I finally got it out after half an hour the plug came out with some metal filings from the primary casing - went back in tight enough but I now have got a few oil drips. I change the O ring out too so I know it's not that.
Just wondered if any of you could advise if there is some way of sealing the plug better until the next oil change and stop the oil? Thanks for any help/advice given.
Old 03-19-2013, 10:14 PM
dmpjr's Avatar
dmpjr
dmpjr is offline
I use teflon tape on all my plugs...otherwise they will leak.
Old 03-19-2013, 10:23 PM
cacolade's Avatar
cacolade
cacolade is offline
Did you put a bit of oil on the new o ring? If not you may have torn the new one.
Old 03-19-2013, 10:24 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
See two previos posts....
Old 03-20-2013, 03:12 PM
Id.Fat Bob's Avatar
Id.Fat Bob
Id.Fat Bob is offline
All good advice! The torque spec on the plugs is 20 lbs/ft. If yours was that tight then you may have other damage to the threads! I have never put sealer on the plugs...just the oiled O ring with proper torque...never had a leak!
HoldFast71
Oil Archive (no new posts)
07-27-2012 07:32 PM
HDGent
06-30-2011 08:30 PM
freebyrd
06-06-2011 05:50 PM
Robtarra39
04-25-2011 06:58 PM
HDDyna2006
12-02-2008 09:17 PM
Quick Reply: Street Bob Primary Sump Plug
