Can't adjust clutch grab zone
I'm very familiar and comfortable with the whole clutch adjustment procedure. However, on my 04 wide glide, no matter how I adjust it (back the adjuster off 1/2, 3/4 or full turn from seated) the clutch will only grab once the lever is almost all the way out. I want it to grab near the middle of the lever travel, like it does on my fat bob. Maybe the discs are just too worn? Not having any slippage though. Any ideas?
Mine was like that once. I made the mistake of adjusting the clutch while the engine was still warm while I was changing my oil. So I consulted my service manual and it said to only adjust the clutch when the bike was cool temperature. So I did it again when cool and no problems. Hope this helps.
Maybe the ***** came out of the ramps and it's inverted 180 under the clutch cover? If that happens I don't think you'll ever get it to grab.
Maybe some clarification. .as adjusted now, the lever disengages the clutch as soon as you pull on it, you want this to happen closer to the grip? That 1/2, 3/4, 1 full turn at the clutch basket isn't what controls this. It's the cable adjuster you need to play with. Visually look at the adjusting screw at the basket as you actuate the lever. Now go loosen up your slack at the lever. It'll cause the clutch to disengage closer to the grip, and as long as the adjusting screw separates the clutch discs the same amount you should be okay. Don't want to get it mid-way then find out you're not fully disengaging the clutch.
Red Dragons, the only way to adjust it to where it grabs closer to the grip is to use the cable adjuster to adjust more slack, or freeplay, into the cable. Follow the manual to adjust the clutch pack, then simply allow there to be some slack in the lever. Unfortunately, there will be more slack in the lever.
