V-Rod Fork Lowers/SD Customs
I'm not trying to bash the shop, just thought I'd gain more views by mentioning a cool shop.... I was talking to SDC about some front end work- mag wheels, dual disc brakes, Works performance springs. I told him about my ideas and mentioned using a Fat Bob right lower, he kind of nixed the idea and said its better to use two Vrod lowers to "keep a stock look" and have the fender bolt up more easily and take out all the guess work. I totally trust them, this is the shop that brought us the Deathstar Dyna and Duffel's White Knight.
BUT I feel like I've seen tons if people say not to use vrod parts because it messes up the geometry and rake of the street bob frot end. This is a very reputable shop, I'm just nervous about getting upsold on TWO vrod lowers instead of ONE fat bob lower. I'm going to meet face-to-face to chalk things up and get a rough estimate, but wanted to hear some opinions.
Personally I would use 2 Fatbob lowers, and build them myself. The damper rod forks are so easy to build compared to cartridge forks there is no reason to pay a shop to do it.
I have no input on V Rod lowers but Big Daddy and Howard know that setup.
Feel free to come do it for me then....I'm getting other work done and I live in a condo complex so I can't have my front end torn down sitting in a parking lot for a couple days while parts are off getting powdercoated. It all kind of snowballed- I was simply going to do a new fork spring kit because I'm tired of the clunky front end, then I figured I might as well get my triple trees powdercoated finally while it's torn down. And I know I want dual disks eventually so I need different lowers, no point in figuring out all the fork oil if I'm just switching lowers in couple months. Then I ended up getting some good deals on mag wheels so might as well throw those on too. I'd rather support the local independent economy rather than the HD dealer.
If you werent across the country from me on the wrong coast I would. Why not just paint the lowers and set the preload on the oem springs . Change the oil to 15 wt and be done?
I did a writeup on this a while back, Link below
https://www.hdforums.com/forum/dyna-...wered-low.html
Dirknar
07-29-2012 10:27 AM
