2013 Street Bob turn signal relocation
Sorry if I'm posting in the wrong section or if im beating a dead subject but I can't seem to find any info on this topic. I just put some 14" apes on my bike and figured I'd relocate my turn signals while I was at it. Only problem is it seems like the wiring is wired right into the controls! Kind of hard to explain with out seeing it but ill try. I got everything disconnected i got the wiring from out of the handle bars but instead of going from the harness through the neck straight to the signal it goes from the frame into my bars then into my controls and into my signal. Doesn't look like there's any kinda screw to just get them off of the controls so I can relocate them. Any info would be greatly appreciated. It would look way better with them relocated
You can get a relocation kit from HD dealer,,Make sure you get the one for the 2013,,If you pull the wires for the handle bars out of the back bone in front of the tank ,You well find a empty plug that is for your turn signals,( One on both sides ) ,,Then you just cut the wires off at the controls,,Get the kit and go from there,,Not a hard job,,And you don't have to remove the tank to do it,,
