larger backrest pad for tapered round sissy bar?
Does anyone know of a larger backrest pad that fits a tapered, round sissy bar? (Specifically Khrome Werks model 263611 -- 14" tall, 9/16" dia).
The pad Khrome Werks specifies for this bar was tiny and had almost useless padding. It was more for looks. I don't care what it looks like when a pad is on it, I just want it to be more functional. Also, I dont mind a universal fit pad, if one exists that works.
I attached a pic of the bar with the pad I originally had. (NOTE: there is nothing between the bars when pad is removed)
I ran a setup like that on.my SB. Yes the pad is practically worthless but it was the only one I found. My pad was a Drag Specialty one. I do not recal anything bigger at the time. Check the Fat Book and some of the seat manufacturers like mustang for any other options. If not you would need to custom mount one of the bigger ones. Perhaps you could remove the mount from your current pad and adapt it to a larger back rest pad.
dukmn80
05-17-2006 10:40 AM
