Says 3 quarts, 2 1/2 looks correct
2011 Fxdc, just got the bike. It has 1280 miles, so went to harley and got 5 quarts of full syn. H-d oil and filter- o rings and derby cover gasket.
Drained the engine oil, By judging from the drain pan The engine only seemed to have maybe 2 quarts in it(old oil looked very black). No metal on drainplug magnet. when i was at the Dealer they said it takes 3 quarts, but I put in 2 1/2 started the bike, let run for 2-3 minutes and checked the oil level. Looks to be correct level? Are you supposed to thread the dipstick in to check oil level?
Also changed tranny fluid, Magnetic on plug had some metal shavings stuck on it. Is that normal? Added 1 quart and level looked good.
Tomarrow night I will change the primary fluid.
takes 3 qts in dry motor. 2 1/2 on a oil change. yes screw dip stick in all the way. servise manual is worth its weight in gold, if you do your on work. if you look hard enough, you may find a used one. ebay maybe
small amount off shavings is normal
Get a manual, you won't be sorry!
