Help with Pistons
Help with Pistons
I was thinking about doing a 107 kit on my 2011 FXDC since Im already doing a 117 on the Streetglide but decided against it. I will keep it at 103 (when I bought the bike Bellmore Harley installed the 103 cylinders for free as part of a buying the bike). I sent out the heads to be CNC polished and ported. I orders a Bassani Road Rage 2 into 1 exhaust, got woods cams and will be using the TTS tuner. Now my question is what about the pistons. Should I leave the Harley cast iron flat tops that came with the 103 kit or can someone recommend another piston and what compression would they recommend.
Youre right they are aluminum. I was typing and thing about cylinders and other things. I will be running Woods 888 cams. Im pulling them out of my 103 Streetglide since Im building it up to a 117. They ran amazing by the way. The SG is running 109 horse and 118 tourque with head work, 58mm tb, 103, and D&D Fatcat.
Regarding valve size on the heads. They will be 1.900 intake and 1.615 exhaust. I asked them put automatic compression releases on the heads as well since I have those on my SG as well. And also in case I decide to bump up to a 107 in the future.
Depends on what your goals are. If you're just looking for a little more compression, you can switch to .030 head gaskets, which is what I'm doing. I'm certainly not an expert, but I've been given the impression on the research I've done that the cast pistons are fine as long as you're not spending much time above 6,000 rpm.
You could achieve the compression you need for that cam with the stock pistons by decking the heads but you could run into clearance issues with the stock size valve reliefs and oversize valves. Wiseco makes a forged flat top with bigger valve reliefs but you'll still have to deck the heads quite a bit. I'd just run the se forged high comp pistons like you had in your stage 4. Are the pistons out of the sg still in good shape? The pistons will probably end up .005"-.008" below deck so I'd run a .030" head gasket. Shoot for 10.5-10.6:1.
I would use forged piston and spend the extra money. Because the metal gets heat treated it goes through the annealing process that a cast piston does not. Since the pistons get super hot and then cool, the metal characteristics in the cast piston will change because it's porous and cause them to break down faster. I would also run 10.5 to 1 compression ratio. The first thing to consider when determining the mechanical compression ratio is, whether the engine will use 93-octane pump gas. What cams you are going to use. I have not had any problem using 10.5 to 1. Just my two cent.
This is my FXDC. I just installed floorboard and used the old ones of off my Streetglide to see how they feel. I also ordered the Bassani road rage 2 into 1 exhaust.
