Power Vision 2 install ???
I will be installing the pv today on my 12fxdc. Where abouts do I connect it to my bike? Also do I basically hook it up to the computer...download the map I received from dynojet tto the unit ....then connect it to the bike to flash the ecm...forgive me but I am green to all of this and want to make sure its done correctly....I also should save the stock ecm config right???? Any input is greatly appreciated...thanks
If you go to the Dyna Jet website in the PV area under "Downloads" there are instructions and videos for everything. Start with the Install guide, it is pretty easy.
The ECM port should be next to your 3 Fuses.
If your PV did not come with a map then yes you will have to download it onto your PV via a computer.
The instructions will guide you on saving your stock map, but don't worry too much about that - you will never want to use it again.
Different plug...2012 13 softwils and dynas.....easiest install ever...literally update the software then the newer power visions automatically store your original configuration when it marries to the bike....then selected a base map....does anyone have theauto tune pro is it worth getting?? Is there a specific tech mount thats preffered?
