Problems with LED tail light
I bought a LED tail light off e-bay for 45 bucks and having problems wiring it into my 07 WG. Its a three wire hook up ground, running and brake light ok that's easy, when I hooked it up to a 12 volt power source on the bench it worked ginger peachy, when I wired it into the bike the running light is very dim with a couple of the LED's brighter that the others??? Back on the bench it's fine, checked the ground everything can't figure what I'm doing wrong, and no I was not drinking during the install, maybe I should of been. Help
Bad connections in the wiring can cause voltage drops to the light.
bfgoodmudder
07-31-2011 11:26 PM
